Need HELP after trans swap...
zx3focus
37
I did the t3650 swap into my 97 cobra and I love the trans and the new clutch. But there one problem. I noticed today that at around 2,000rpm it has a vibration to it. I think it may be the the clutch/flywheel but I am not sure. I used a flywheel that looked good and had about 19000 miles on it. I didnt get it resurface, I just used sand paper and got the glaze off of it. Also I put the driveshaft back in the holes where it had been the last 9 years. The vibration is bad because it right about 65-70mph in 5th. And it is enough to numb your legs. Also it is not constant. It is like a humming that comes and goes consistantly about every 5 seconds when I am cruising at around 70. Any ideas??? THANKS
still vibrates...but I get a similar vibration when the car is not rolling and I rev it to 2 grand. So it may be a bit of both. But i am not sure. I was going to index the d/s today I can clearly see where it was from the factory.
its just hard, because you have to lock tires to tighten 1 bolts, unlock your tire, spin the shaft, and lock it then tigten. its bit time consuming. So sometimes people don't do it right
