Need Help ASAP (91-93) Hazard Lights
Dan P.
483
N.C.
I need someone with a 91-93 to take a picture of the wiring for the back of the hazard switch for me please. You can also write the color codes but a picture would be better.
Thanks,
Dan
Thanks for the pic !! I was wondering if you could clarify something for me. One do you have rear defrost and two what color is the wire next to the bottom left wire thats orange and yellow?
Thanks for the help,
Dan
I do not have rear defrost this is on my 93 vert I am putting a 94 SHO motor in. The switch next to it is the top switch.
Ok bottom left. Next wire hole up has 2 wires in it. Orange/blue and white/blue.
On the rear defrost. I have a old harness for a 93 coupe I will look for it tommorrow or will try looking thru my wiring diagrams and let you know that. Maurice
On the rear window heater switch. My diagram shows wiring for window and top as same wiring. Now with key part of plug the right. I assume looking at wire into plugs. top to bottom.
purple 588
brown/light blue 186
gray/light blue 688
purple/orange 298
I assume numbers are on the wires.
I need to I can look up the hazard also.
Maurice
