  • SN95 4.6L Mustang Tech
Need help ASAP....please!
  • Thread starter Thread starter cobra2798
  • Start date Start date Jan 19, 2009
1 of 2 Next Last
cobra2798
303
Clermont, Florida
Jan 19, 2009
  • Jan 19, 2009
Got a problem. I just tookmy car through the car wash and about 5 mins later I was just driving like normal and I heard a snap noise,not loud but you could hear it and the car suddenly lost alotof power and was making a ticking noise, when I get on it it does not have near the power it did. It runs and idles smooth yet is ticking and has lost alot of power, what could this be? Did I blow a plug oris it something worse?
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 19, 2009
  • Jan 19, 2009
Took it through the car wash...does this mean you sprayed under the hood also?
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Jan 19, 2009
  • Jan 19, 2009
any chance you caught the exhaust on something in a drive through carwash?
need more info.
joshjwc9
1,095
17
39
Palm Harbor, FL
Jan 19, 2009
  • Jan 19, 2009
CEL on?
cobra2798
303
Clermont, Florida
Jan 19, 2009
  • Jan 19, 2009
joshjwc9 said:
CEL on?
No.
The best way I can describe it is I was driving at about 40mph in 3rd, car infront of me slowed down and I shifted into 2nd, soon as I put my foot on the gas I heard a faint snap or pop noise from the druivers side front and the car instantly lost alot of power and was making a ticking noise. It runs(not good) and idles smoothly. It lost alot of power and sounds like a truck. Im at work so there is nothing I can do now.
Now if it was something bad like a spun bearing or a bad valve seal would the car run? Im fearing the worse. Its just wierd that it happened right after I left the carwash, it was running so smooth and so strong. Any ideas?
squeak93
2,348
417
164
Joplin, Missouri
Jan 19, 2009
  • Jan 19, 2009
U didn't answer whether u washed under the hood or not.
joshjwc9
1,095
17
39
Palm Harbor, FL
Jan 19, 2009
  • Jan 19, 2009
Plug wires all on tight? Let the car cool and check the oil level.
I am surprised that the CEL is not on because it sounds like a misfire/clogged injector since you say it is smoothly idling.
No knocking/detonation? Does the car struggle to start?
BurningRubber
1,865
24
58
Jan 19, 2009
  • Jan 19, 2009
Spark plug is my bet.
Let the engine cool down, remove your coil packs and see if a plug is flopping around... if you have some tools check them with a socket and see if they are loose.
trinity_gt
3,125
81
99
Canada
Jan 19, 2009
  • Jan 19, 2009
cobra2798
303
Clermont, Florida
Jan 19, 2009
#10
  • Jan 19, 2009
  • #10
I did not wash under the hood. Car starts as it normaly did, just fine, idles like it did, just fine. It is making alot of tiking noise and has lost some power. Oil levels are fine, I just changed it last week. Im gonna check the plugs when I get home. Any other ideas please let me know and thanks for your thoughts.
squeak93
2,348
417
164
Joplin, Missouri
Jan 19, 2009
#11
  • Jan 19, 2009
  • #11
Sounds like a plug to me as well. check those and keep us updated. Could of had a cp die, but I'd bet on a plug first.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jan 19, 2009
#12
  • Jan 19, 2009
  • #12
Spark plug being loose or blown gets my vote. Let us know what you find out.
cobra2798
303
Clermont, Florida
Jan 20, 2009
#13
  • Jan 20, 2009
  • #13
So I pulled the plugs and all were ok but 1. It was the second from the back on the drivers side. The plugged was covered in a black slug which I would imagine is oil. Cleaned it up and still no difference. Im sure this is not good
So the short story
-heard a pop noise and car became sluggish and made a loud ticking noise
- found oil covered plug
- cleaned and found no difference
- loud ticking and very sluggish
Ok give me the bad news...what is it?
squeak93
2,348
417
164
Joplin, Missouri
Jan 20, 2009
#14
  • Jan 20, 2009
  • #14
Sounds like a ring issue. Could be a valve seal. Does it smoke when u get on it or anything? U might have to have someone watch for u. My motor dead in one cylinder and 1/2 dead in another, it barely smokes and only when I hammer on the gas.
cobra2798
303
Clermont, Florida
Jan 20, 2009
#15
  • Jan 20, 2009
  • #15
Hardly any smoke at all. What is causing the ticking noise? Do you drive your car with the dead cylinder? My car has no pwer, feels like Im driving a semi.
LaserSVT
3,548
233
Jan 20, 2009
#16
  • Jan 20, 2009
  • #16
Rod knock. Sounds like it was just coincidence and the engine choose that time to let loose
Need a recording of the sound its making. Also, just for my curiosity, check the intake piping and make sure its not leaking after the MAF.
squeak93
2,348
417
164
Joplin, Missouri
Jan 20, 2009
#17
  • Jan 20, 2009
  • #17
I drive the piss out of it with the dead cylinder. Planning a full motor pi swap here in a couple of months, plus its not my daily so not really worried about it letting go. I just don't venture to far from home with it.
Oh and check what svt said, that is possible. But does sound as if something let go inside. Just bad timing as to when to do it.
cobra2798
303
Clermont, Florida
Jan 20, 2009
#18
  • Jan 20, 2009
  • #18
Here is a vid, dont know if it will help. Also intake piping is tight.
myponyrocks
Apr 18, 2004
1,219
Jan 20, 2009
#19
  • Jan 20, 2009
  • #19
sound slike something flopping around to me. I'd pull that valve cover and take a peek.
Stark77
501
Tallahassee, FL
Jan 20, 2009
#20
  • Jan 20, 2009
  • #20
WHOA! You can hear the friction in that video. I'm gonna agree with Laser on the bad rod - or you may have thrashed a valve (slim to no chance if you're running stock cams). Pull those valve covers first and see if everything looks normal. How about some in-car footage? Drain some of the oil and look for metal shavings as well.
1 of 2 Next Last
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
