ok 2night i went to my friends hous the car did fine went to cranck it to move it and nuthing would happen. i poped the hood and grabed the positive wire and sparks jumped with the key off.i tightened the positive side down some and the negative side started trowing sparks then a couple seconds later i see sparks from under the car from were i think the negative cable ataches to the block then i move the negative again and the car tryes to start and run me and my friend over while no one was in it the key was off and the clutch was not even pushed in. then i saw smoke come from the starter sylinoid and the positive wire sarted melting so i grabed a wrinch while my friend got in to hold the break so it would not run me over and i riped the positive wire off the battery. i got in the car and checked the power relay and it was melted again but this time i could not get it off it was like it was welded shut ive had a problem with that for ahile but its never done this before. if anyone has and idea to what i could do i could use it because im about to start looking for a new car or something because i dont want to replace the wiring harnise which i do have one out of my convertable will that work in a hatch? it should shouldent it
also sorry for the bad typing
