my shifter is stuck in neutral. It won't move up, down, or side to side.
Also, it is stuck in fourth gear (if that makes any sense). Basically, it's in the neutral position, but still in gear.
I tried starting it and then letting off the clutch to see if that might break it loose....but all it did was move forward. The clutch assembly is in perfect working order.
Background: I jacked the car up, finished the wire hiding I was doing, and then lowered it back down. I heard to rather loud "pops" when I was lowering it...but I thought that was just tension in the suspension. Also, when I had it jacked up, I moved the shifter from 4th, to neutral, and back to 4th. Other than that..nothing else was done. The car didn't even move.
Any and all help is greatly appreciated,
Clay
EDIT: I doubt the transmission could have messed up...but if it did.....then it's a perfect time for a t56 swap
Clay
