Need some opinions help on the following problem:
Coolant leaking top of timing chain cover - so I replaced timing chain cover
still had to keep adding coolant. Block is dry all the way around engine except for driver side rear - wet under head - probably head gasket. Car runs great no smoke out the pipes.
New (and main problem) - Past two days started car up to idle in the am while I get the kid ready for school. Come out probably 10min. and Stewart Warner temp gauge reads 220deg. I open the hood and coolant overflow is full and overflowing.
yesterday I blipped the throttle and temp dropped. I can drive around all day and no problems. Has only done it twice in the am when first start up. Thought about thermstat or water pump. If all the coolant is being held in the radiator then doesn't it seem llike the pump is not pumping???
Any help would be greatly appreciated
Thanks
Thanks
