Need help deciding which setup for 67 mustang
MySecondPony
ARP 154-3601 - ARP High Performance Series Cylinder Head Bolt Kits - Overview - SummitRacing.com
COMP Cams K31-238-3 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
Crane Cams 11746-16 - Crane Energizer Roller Rocker Arm Sets - Overview - SummitRacing.com
Summit Racing SUM-56250HSPS - Summit Racing® Bolt Kits - Overview - SummitRacing.com
Trick Flow Specialties TFS-51400002 - Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford - Overview - SummitRacing.com
Trick Flow Specialties TFS-51400419 - Trick Flow® Head Bolt Bushings - Overview - SummitRacing.com
Weiand 8020 - Weiand Stealth Intake Manifolds - Overview - SummitRacing.com
This setup I got it from someone in a forum, is a little cheaper than the edelbrock.
Unless I'm missing something.
Edelbrock 2091 - Edelbrock Power Package Top-End Kits - Overview - SummitRacing.com
Edelbrock 77780 - Edelbrock Aluminum Roller Rockers - Overview - SummitRacing.com
Edelbrock 9632 - Edelbrock Hardened Steel Pushrods - Overview - SummitRacing.com
This is the Top End obviously, with roller rocker arms.
Holley 550-400 - Holley Avenger EFI Engine Management Systems - Overview - SummitRacing.com
EFI, Why not. But would it work in either setup?
MagnaFlow 15816 - MagnaFlow Performance Exhaust Kits - Overview - SummitRacing.com
Patriot Exhaust H-8426-1 - Patriot Full-Length Headers - Overview - SummitRacing.com
Needed to upgrade from a 2.00 setup and stock manifold.
Gear Vendors under/overdrive auxiliary transmissions Hot Rods, Ford 3-Speed Automatic Muscle Car/Street Rod/Restoration.
Like the idea of just swapping it back like nothing was ever there and from where I come from swapping to an AOD or 4r70w was about the same.
Just Rear Ends - Product Display
I have open 2.79 enough said. Sorry I do need help in which ratio. Open to suggestions from 3.00 to 3.55 only.
I got a week of vacation coming up in mid August, any input would be greatly appreciated.
Thank you
