NEED HELP, DESPERATE!
  • Thread starter Thread starter kornymofo
  • Start date Start date Sep 4, 2007
K
kornymofo
  • Sep 4, 2007
I have a 90 gt and have a problem with the car overheating. the temperture consistently rises and almost reached red the other day. it does this in about ten minutes and when it gets really hot makes a pinging sound. the oil level is fine but i do have a blown head gasket now because of it. i just replaced the thermostat and that didnt seem to do anything. so im stumped. anyone got any idea?
i need my car fixed really soon. i deliver so i really need to have my car to continue to make money. thanx.
-james
91 HATCH
Banned
May 17, 2007
262
illinois
Sep 4, 2007
  • Sep 4, 2007
to much timing can get it hot and make it ping
change the head gaskets
88mouse
630
Mooresville nc
Sep 4, 2007
  • Sep 4, 2007
Check the fan clutch. But i wouldn't be driving it to much with a blowed head gasket your really not going to beable to tell untill thats fixed.
squeak93
2,352
418
164
Joplin, Missouri
Sep 4, 2007
  • Sep 4, 2007
Your radiator could also be clogged. Flush it while ur changing ur head gasket as all the fluid is most likely contaminated.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Sep 5, 2007
  • Sep 5, 2007
Are you sure the overheating caused the blown head gasket or did the blown head gasket cause the overheating? You definately won't be able to tell if it is fixed until you fix everything. I'd start off with the new head gaskets and head bolts, flush the cooling system, check the thermostat (or swap to 180*), check the fan clutch (or swap to electric), inspect the radiator, and get some fresh coolant (try using distilled water instead of tap water).
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 5, 2007
  • Sep 5, 2007
i cant believe this hasnt been said yet. check the water pump. open the cap oon the car and see if water is moving? hell even double check to make sure water is in it. im not trying to talk down to anyone but you can never be to carefull.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 5, 2007
  • Sep 5, 2007
EXACTLY!!!! We just covered this yesterday with Strype. CORNYMOFO......Read the thread he started. Sorry, I noticed your a newbie....but we did talk the Strype about this, he may have it fixed by now.
WHEN TRYING TO SOLVE AN OVERHEATING PROBLEM....REPLACE ALLLLLLLLL PARTS...INCLUDING A 25 DOLLAR REPLACEMENT WATER PUMP THAT TAKES LESS THAN AN HOUR TO CHANGE!!!!!
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
