Fuel Pressure Update
OK. So here's the deal. I have replaced my fuel filter. It was yucky, but had little effect on drivability. Maybe a little better, maybe the same. I bought a new Fuel Pressure regulator, but they are not replaceable on the late 1998 cars. They are welded onto the fuel rail. I did install a Accel Fuel Pressure guage on the schrader valve. Here is the deal. After sitting for 1/2 hour Fuel pressure is @ 3 PSI. Turn key to "on" but not all the way to start, pump kicks on for 3 seconds and pressure goes to 42 PSI. Pump Turns off and Pressure drops to 15 PSI within seconds. I can repeat this process 3 or 4 times but the effect is the same. Within seconds the pressure is 15 PSI and from there it slowly (about 1/2 hour) bleeds to 3 PSI. If I get it to 15 and start the car, it goes right up to 40 PSI while cranking and then drops to 35 PSI when it fires. So what we know for sure is;
1. My fuel system cannot hold more that 3 PSI for any amount of time.
2. There are no external leaks in the fuel system.
3. My pump is capable of bringing the system up to 42 PSI and maintaining 35 PSI.
This leads me to beleive that
A. Fuel is getting back to the tank either by flowing past the pressure regulator through the return system which means a bad regulator, which means I have top change out my entire fuel rail system $$$$$$$$$$$$$.
B. Fuel is getting back to the tank by flowing back past the pump which means bad pump, but the 42 PSI kind of makes this less likely.
C. Fuel is leaking out 1 or more injectors that are stuck open
But even though it is running king of rough, it still has ALL of it's power when I get on it which I think rules out B and C. I mean if the pump is shot how is it going to deliver enough fuel for full power @ 6000 rpm? Along the same vein, if an injector or 2 is stuck open all the time, what are the chances that the mixture would be correct to make full power when I get on it from idle to redline?
Any thoughts or advice are greatly appreciated. Thanks again for all the feedback so far.
