  • SN95 4.6L Mustang Tech
need help fast,
  • Thread starter Thread starter johnnyt03gt
  • Start date Start date Sep 25, 2010
johnnyt03gt
5 Year Member
Mar 15, 2008
453
dallas TX
Sep 25, 2010
  • Sep 25, 2010
my radiator sprung a leek, my buddy works at autozone can hook me up with a V6 radiator for FREE,
just need to know if V6 radiator will work on my V8?
Stumbaugh
903
Russellville, Ar
Sep 25, 2010
  • Sep 25, 2010
Your buddy from Autozone should be able to tell you this. If he will look up the part number on a radiator out of a gt and write the part number down, then look one up for a v6 and compare part numbers.
johnnyt03gt
5 Year Member
Mar 15, 2008
453
dallas TX
Sep 25, 2010
  • Sep 25, 2010
it's his off day, the outer guy i asked said they are not the same
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 25, 2010
  • Sep 25, 2010
Short answer. NO. The V8 and V6 radiators are different. I suspect the V8 is bigger or has more fins. It may even have different size inlets/outlets.
Try this trick. Go to oreillyauto.com and look up the part. Click on the compatibilty tab and look at the other models the part also fits. Only V8's are listed.
Murray 431396 - Radiator 2003 Ford Mustang | O'Reilly Auto Parts
streethorse
1,042
Dallas Texas
Sep 26, 2010
  • Sep 26, 2010
What ever you do, dont put stop leak in there......
Maxpowers
859
Pittsburgh, Pa
Sep 26, 2010
  • Sep 26, 2010
x2 unless you don't plan on putting many more miles on the car.
I would recommend taking the rad out and taking it to a rad repair shop.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 21, 2026
M
What changes need to be made to the brake system after swapping a V8 rear axel into a V6 1999
  • MARTYMAN
  • Jan 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 22, 2026
Mustang5L5
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
