Need help for the newbie
slow_93_stang
23
ok got the car running....it runs great set the timing at 12degrees with the spout dissconected. reconected the spout and the timing starts going crazy. jumping around and not running worth a @#$%. with it disconnected it runs great but doesnt make any power. just kinda pulls along at a snails pace. so what could be the problem......thanks for the help
:bang:
with the spout out your setting the base timing. Make sure
A: the car is off
b: remove the spout
C: start car , use timing light set at 10*, LOCK down the distrubter!
D:doublt check the timing with the spout out and dizzy locked down
E:turn car off, plug spout back in
F:Turn car on and your Base timing is now Set at 10*
after the spout is back in, the timing will jump all over the place, its now being computer controlled. Your computer already advances timing to make power...advancing the base timing is just some *fine* tuning.
coming from the TFI module on the distributor there is a harness with like 4 or 5 wires... about 2 or 3 inches out there is a little two wire connector that just hangs there... the spout is the piece that connects into that. just grab it and pull and it will come out.
