- Nov 27, 2005
- 89
- 0
- 6
Hello all im new to this forum but not to mustangs or Fords. for that matter. I recently purchased a 1990 Lx coupe. Really a good deal for the money spent & I feel like I got the better part of the deal. Here is spec's on the engine & my question following car info.
stock block bored .030 with trw forged pistons
Edelbrock 60259 aluminum heads
Crane 1.6 magnum rollers
Comp Cams hardened push rods with guide plates
Trickflow stage 2 cam
C&L 76mm Mass air
C&l Pro tube
Holley 80mm throttle body & egr spacer
Holley Systemax II Ported upper & lower intake
36Lb Ford injectors
Mac Direct fit hts coated shorties
Pro chamber 3" exhaust with flowmaster 40's with dumps
I think that is basic info so far the short block has under 3,000 miles on it, the owner of car pulled the upper end down to install the heads & intakes, when I purchased car the motor was disassembled from the heads up. the heads & holley systemax setup is like brand new doesn't even have any stains on them yet. I got all the upper end of motor togather & mounted the accessories including the distributor wires etc.. The car turns over fine & fires hot enough to knock you on your ass if holding the wire away from coil "speaking from first hand experience". But it doesnt seem to be getting any fuel through injectors? I have walbro 190lph pump & do not know what fuel pressure is set @ as I havent purchased a fuel pressure gauge yet. I know motor has good compression & is in time but not even a glimmer of a sound of trying to start. Any ideas???
Bill
C&L 76mm Mass air
C&l Pro tube
36Lb Ford injectors
Bill
