NEED HELP!!!! FRONT END CONVERSION ??
  • Thread starter Thread starter chitownstang
  • Start date Start date Apr 1, 2004
C
chitownstang
Chicago
Apr 1, 2004
  • Apr 1, 2004
I have a 88 coupe that i purchased with a 5 lug front conversion I need to re-pack my front berings and I'm not sure what to parts to purchase??? 94-95 mustang? How can I Tell????
Thanks for your help.
Chitownstang
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 1, 2004
  • Apr 1, 2004
If the brake disk and the hub are one piece, use the stock 86-93 bearings. If the brake disk is separate from the hub, it uses 94-up bearings.
trbkrb
1,976
Houston, TX
Apr 1, 2004
  • Apr 1, 2004
If you remove the tire and the brake rotor can be moved around on the studs, meaning it is separate, then you have the SN95 setup and need 94+ hubs. The bearings are not repackable, and you have to replace the whole hub assembly with the studs. They are held on the spindle by a large nut under the dust cap, that is torqued on to like 220 ft/lbs. The nuts are NOT reusable.
If the studs are part of the rotor, then like jrichker said, get the same bearings for the stock 88 model.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
