need help guys fast noise comming from the engine
stanggt00
371
baltimore md
i toke the car for a hard 1st,2nd, and 3rd gear run to red line
after installing 75mm tb and plenum and now i am getting a tapping noise from the motor
the noise is not heard at idle but anything over 2k and the tapping noise increase with the engine rpm
its not crazy loud but i can hear it from inside the car and out side of the car at higher rpms
i tried to use a long screw driver to see if i can hear were the noise is comming from i know its on the driver side but not sure if its in the head or bottom-end
the car was not over heating there was plenty of oil in her and i dont feel a lost on power
plz help if u can guys thxs :bang:
If it sounds like a clock ticking then it could be an exhaust leak or the lifters. While the car is running, take off the oil cap and stick your ear in the valve cover. If the ticking is coming from there, its probably just a lifter tick, nothing to worry about really. But since you did all that exhuast work recently, it's probably the connection where the X pipe meets with the exhaust manifold.
+1 I have BBK LT's and a BBK H pipe and I have had to replace the collector gaskets. The fact that it developed after you were jumping on it through the gears supports this theory... You probably just blew out part of the gasket/dounut. Hopefully thats all it is because as you know its a quick and easy fix.
