Need help guys
  • Thread starter Thread starter JoshP82
  • Start date Start date Jan 23, 2006
J
JoshP82
91
Burbank, CA
Jan 23, 2006
  • Jan 23, 2006
I had my stang in storage for about 4 months and today I started it up and I heard a squeak and noticed smoke was coming out of the the botton left pulley and was not turning , Is that one the smog pump??? And can I just replace the pulley itself or will I have to buy an entire new one?? Took a quick picture of it, help me out guys thanks.
old_blue
1,783
282
124
Jan 23, 2006
  • Jan 23, 2006
my first thought would be to bypass it but that may not be doable. take the belt off and seee if you can turn it by hand, see if it is binding on something. Also check to see if everything else is in aligment on the belt. I would call ford or checkers, they may have a new pulley for it. I know they sell the pulley/clutch assembly separate for the a/c so you might be in luck.
livenfine
601
  • Jan 23, 2006
Your smog pump seized up. Replace it $100-ish or buy a smog pump delete kit, ($45-ish), if your state's emissions will allow it. We don't have emissions here
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 23, 2006
  • Jan 23, 2006
I thought new pumps were only like 25-30 from most parts stores.....
If you need to pass emissions you can't remove it.
old_blue
1,783
282
124
Jan 23, 2006
  • Jan 23, 2006
he is from CA, gotta have it
livenfine
601
  • Jan 23, 2006
Smog pump
Mustangs unlimited. $90 + shipping...
Might find one used...
Good luck
J
JoshP82
91
Burbank, CA
Jan 23, 2006
  • Jan 23, 2006
Thanks guys now heres a couple questions do u think I can replace it myself??? im a newbie never really did anything to my engine except for the Cold air kit thats about it????
HISSIN50
34
129
Jan 23, 2006
  • Jan 23, 2006
It is easy to replace yourself. Parts stores charge about 40-50 bucks for a reman'd version. LRS also sells them for about 50 bucks, IIRC (I dont know if it is new or reman'd).
The pumps use vanes that are on a shaft, and that shaft follows an elliptical path. Corrosion can really create some issues inside there, when a pump is not used for a bit (that is a tip from Jrichker about time of non-use taking them out).
I opened one up to clean it and you can see that a little main bearing play (run-out at the shaft) would REALLY create issues with the vanes hitting the walls (what the one on my 94 does).
Good luck.
04sleeper
2,674
14
89
Dallas, TX
Jan 23, 2006
  • Jan 23, 2006
I have one laying around somewhere. PM me if you are interested.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 24, 2006
#10
  • Jan 24, 2006
  • #10
always do simple swaps like this yourself save you major coin for more mod parts.
rd
3,316
63
109
Ocean Springs MS
Jan 24, 2006
#11
  • Jan 24, 2006
  • #11
If you mean the lower pass side of the motor, its the smog pump. I changed my 266,000 mile original earlier this week with an Autozone unit, $35 plus a $10 core charge. Takes 30 mins or less.
You can try to take the belt off and turn it by hand to break it loose. If you can, it will be ok for awhile.
These have a very large surface on the rotor, that is very close to the casing. If they do not turn, surface rust can quickly jam them. Early ones were notorious for doing it during shipping when the cars were new!
J
JoshP82
91
Burbank, CA
Jan 24, 2006
#12
  • Jan 24, 2006
  • #12
Thanks guys just got one from Autozone 40 plus 10 core charge im gonna try and tackle this right now or early tom and see how much i screw up lol. Thanks for all your help guys
QDRHRSE
1,590
Palmdale, CA
Jan 24, 2006
#13
  • Jan 24, 2006
  • #13
he can just get a short belt and bypass it. 20bucks.
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
