- May 12, 2005
- 208
- 0
- 0
Ok, It's a 302 H.O. Completely stock engine. I will be hopefully completing the full rebuild tomorrow (finally got some time to work on it). So I have everything pretty much completely assembled. There are just a few things left That I am lost..--The engine was disammebled when I purchased it--I am not a complete moron.
1. Anyways he labeled one of the hoses-lower water pump hose to plastic fitting. Not sure where the lower water pump hose conects too.
2. There is a threaded hole on the lower intake . Not sure if a sensor was there or what. THe part is missing? It's on the passenger side on the front of the intake, about 1 to 1 3/4 inch diameter threaded hole.
3.There are two hoses (They look like coolant lines, but may be vacuum lines.) on the plenum. One protuding from each side of the plenum (upper intake) right behind, or maybe even on, the throttle body.
Also there are 3 more attached to and coming out from under neath the rear of the plenum that I also am not sure of.
4.Lastly, I have one bar that I don't know where it goes. It looks like a stove handle in shape. It's about 3 inches long and maybe 1/2 thick in diameter.
All help is greatly appreciated, and I hope to have this running Tomorrow, or maybe early net week.
