need help. Idle Problem
supercharged91
I have a problem with my car. You can crank it up and it will idle fine, but when you go down the road and come upon a stop sign and stop it will go dead. It will surge a little from 500-1500rpms and then go dead. You can then crank it back up go to the next stop and it does the same. Pull in the drive way idle surge a little and then either go dead or idle fine. Mods are as listed:
30lb injectors
Lightning Mass Air meter with a Load I/0
New TPS
If need more info let me know. Any help is much appreciated.
