Need help installing a original 93 Cobra intake
This weekend I am planning on installing my Cobra intake manifold and Accufab 65mm TB. I need all the gaskets, upper to lower, head to manifold, and TB gaskets. My problem is I need the correct ones. I looked on Summit Racings website and the upper to lower gaskets come in a pack of five. There are all sorts of brands that offer lower manifold to head, some that appear to only provide the manifold to head gasket (FRPP), and some that include the cork gaskets to seal the front and back of the upper manifold. What should I get? Should I just walk into a Major Parts Store and ask for all these gaskets for a 93 Cobra, or V8 Explorer, or should I go to a FRPP dealer and try to work it out? I need to try and get the gaskets by late Friday. Any input would be great, thanks!
Either go to Autozone and ask for a gasket set for a '93 Cobra or even a regular 5.0 if they don't have that (same part really) or go to a local speed shop and get a set of Fel-pro 1250's.
The 1250's are a little larger and more expensive, but if you have stock heads then just go for stock replacement from parts store.
napa sells victor reinz gaskets (if needed i can get the #) for the 93 cobra, i would get those otherwise the stock gaskets will be to small for the intake and cause a flow distirbance, which is no good, plus the victors seem pretty good, i only used the upper to lower, but the other looked very nice too.
bryce93lx
A Napa part number for the victor reinz gaskets would be great. Thanks.
My main problem is I need all the intake manifold gaskets, and 65mm throttle body gaskets, because the Accufab TB is used and doesn't have gaskets.
Does anyone know if the 5.0L V8 Explorers had a 65mm Throttle Body as well as the GT-40 style intake manifold? If so those gaskets would be a lot easier to find. We have several stocking Ford Motorsport dealers here in the Salt Lake City area, but I doubt even they would stock all the 1993 Cobra intake manifold gaskets.
Thanks everyone.
The 5.0L Explorer's did indeed come with a 65mm throttle body, there are a number of us who run modified Explorer throttle bodies instead of buying an aftermarket.
I'm running an Explorer 65mm gasket. If i remember correctly, i just asked for a parts store explorer gasket.
SInce there is no coolant inside the cobra intake, this gasket isn't that critical, you just need to seal against vacuum leaks.
Some things to help you on your way...
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Wala! no leaks, and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together. Take the other advice you got here and run with it.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 3/4" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
Does anyone have a part number for the part referred to in this thread:
"Short formed hose between thermostat hosing and intake manifold"
Also, what size vacuum line should I get 7/64 or 1/8? I have an 89GT that I"m in the process of GT40p swapping.
Thanks!
