Been there done that.
First, take your guage cluster off. Get to the relays/switch that turns your lgiths on and off (and of course, take the knob off to get the guage cluster off...)
Now, remove the two bolts the hold the light switch in.
Pul it out, inspect the wires. Are they melted? Find which one is hot (functioning), and while being verrrrry careful, get a short wire (speaker wire, anything), and jump from the hot one to each other slot (youll knwo what I mean by each slot). By this I mean stickone end of the short wire into the hot wire, then put the other end into the other slots, various lights should come on.
By process of elim you can see whats bad.
Or, if a wire is visbly burnt, track it, cut it, replace it.
Wiring is one of the biggest hassles EVER to work on. This might help you out.
