Just trying to get some opinons and experiences on MT drag radials I already have 28x10.5 et drags just seeing if I should try and get away with riding around on slicks or opt for the radials.Will be trailered to the track and driven around for short cruises IE True street class
also which radials are comparable with my ET drags? also here are my mods to help you decide low 10sec on motor high 9sec on spray
thanks in advance
1989 4 cyl notch
IMHO a Badass two tone paint job
custom interior all black painless switch panel kirkey race seats
12 point cage painted to match car torque boxes and sub frames welded
all wolfe race craft rear susp, 8.8 TA girdle, 4:10, 33-spline pro race
all PA racing front end tubular K member, A-arms, AJE coil over BBK Cast/Camber
strange 10-way adjus all 4 corners
C-4 done up by local shop billet servo good clutches
4500 coan stall
chetah shifter
wheels
centerline telstars 15x4 & 15x10
69 351w (408) 11:1 all eagle 4340 internals 2000 bolt option
girdle,canton oil pan
JE pistons
AFR 205 nitrous port option
ED curtis solid roller tight lash
ported 351w victor junior
csr water pump
130 amp alt
crower link bar lifters
comp pro magnum rockers
rocker stud girdle
kooks 2" to 3.5 headers dr gas 3" X pipe & bassani for mufflers
pro systems custom 870 cfm carb
NX express Hitman
Barry Grant 280 pump sumped tank 1/2" line BG fuel pre reg
thanks in advance
1989 4 cyl notch
4500 coan stall
chetah shifter
wheels
JE pistons
csr water pump
130 amp alt
rocker stud girdle
NX express Hitman
look @ chart and tell me what you think
around here and plus david wolfe went 7.40@197mph on this tire
nuff said I'm getting them just trying to figure what size fits without minitubbing
