- Oct 12, 2011
- 23
- 0
- 2
Hi Everyone I want to Start of by saying that i have totally gived up on tryingto fix my car and iam to the point were i feel forced to take my car into a shop but i want to try avoid doing that and try to fix my self if possible, problem started since one night i raced someone on the freeway and over reved my car to about 5500-6500 for about 8 seconds at the most here's abrief description of what my 1990 mustang 5.0 v8 does:
When leaving from home to work in the mornings cars drive perfectly fine has lots of power but once car warms up to regular temp 160 - 180 which take about good 15min. to 20 min dr., car starts acting funny shakes when i take off from a dead stop i can hear the change in engine sound when at idle and while driving and accelerating car losses somewhat power.
Thing I have Installed my engine:
Stock 302 V8 5.0, upper and lower cobra intake, 24lb injectors, calibrated maf pro flow for 24 injectors, e303 cam 190 bbk fuel pump bbk adjustable fuel pressure regulator, stock heads, bbk shorty headers, bbk cold air intake, bbk 75mm throttle body.
Thing I have done to Try to Fix Problem Changed Spark Plugs, Distribuitor set my timing to 12,Spark Plug Wires, did oil Change Clean Maf, Changed Idle Air Control Valve, Changed Tps Sensor set to .98-.99, Changed Egr, Changed Egr Sensor, Changed Coolant Temp Sensor, Changed Air Temp Sensor, changed injector wire harness, Changed Fuel Filter, changed o2 sensors, changed computer Checked fuel pressure pressure is good, cheked for vaccum leaks vaccum is good, got good battery voltage all grounds are good.
Please let me know if iam missing anything, anything would be really apreciated and helpfull thank you very much everybody
