Need Help Please weird Problem 87 gt
MY 85 GT
1,852
208
104
New Jersey
I have an 87 GT vert AOD..Just had the car in the shop Had alot of work done to it...Well now while driving the car it just shuts off like you turned the car off....It will crank but not start,,,After awhile it will start back up again...Now Yesterday it did this i called the shop he walked me thru a few things.1st he said take the spout out try it cranked didnt start,,then he said see if i have spark take the coil wire off the cap and lay it next to the terminal i did i had a friend crank it well it started then stalled he said then put the wire back on so i did,tried starting it cranked...pulled the coil wire off then had my friend re-start the car started and i put the coil wire back on made it back to work.... after work after about 15 minutes of driving the car did the same excat thing shut off while driving....did the same steps again got it started..I have no idea what it could be...I replaced the coil with an MSD coil,msd cap,rotor,wires,new plugs,New fuel tank,new fuel pump,New Module....the only thing not replaced is the mag pick-up....in the dist.What could this be any ideas NEED HELP...only can drive the car for a few minutes at a time...... :(
Sounds like a bad ignition module. Take it off and have it tested...make them test it several times so it gets hot and see if it starts acting up. I know you already replaced it but if you bought a cheap one it could still be bad.
I see you changed the module but they can be bad out of the box, they can be tested just have the test done enough times to get it hot so you don't get a false test. could also be the PIP sensor in the dizzy.
JRichker has very good cranks but no start check list that is very helpful over in the tech section but I'll give you the link, check it out.
http://www.stangnet.com/mustang-for...o-start-checklist-fuel-injected-mustangs.html
Well i had a new one on it did this...thought it was defective put the original one back on that was on the car before i did all the work to it.... Guess what does the samething ., 2 different modules...Im wondering if its a bad Mag pick-up in the Dist. or a defective MSD coil....:shrug:
LOL we where typing pretty much the same answer at the same time :rlaugh:
I took longer getting the link to help him but I thought that was funny :D
Yes the replacament one is a cheap one form Advance the original one is a motorcraft..I just replaced it for the sake of it nothing was wrong with the orignal MODULE....Thats whats in there now still doing the problem the shop that did the work said to replace the module and Mag pick with brand new motorcraft parts right from Ford..But you guys are missing that i Have an MSD coil and that the car started with the coil wire laying next to the terminal on the Dist cap isnt that weird? I had started the car and then put the wire back on the cap....I dont know i think that is strange :shrug:
By now you have probably learned that just swapping parts is expensive and time consuming. So It is time to switch your approach and do some diagnostic work...
When the car won't start, do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 05-Aug-2010 to add check for distributor timing in paragraph 6C.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
did not read the entire post,
and cant remebr the name of the thing,but the key tumbler has a module that gets loose/defective and will shut the car off, i had this issue and i finallyfigured it out cause i held the key in place and no more problems..... 15-20 bucks at auto store and fixed......
sorry if this is not even close:rolleyes:
Ok I have an Update the car was flatbeded back to the shop yesterday..I got home from work and shut the car off tried to re-start it and all it did was crank...When he got the car it did the samething just cranked,,,He said there was 12v power at the coil and he changed out the Dist for me with a New Ford module and Ford PIP...He said the car started right up and was running fine...Also before when this problem was happening the car would pop and buck once in awhile then sometime run great..some systoms i have been reading say the PIP was going bad sound right?...I hope the car is ok now i drive it as my daily and i dont need to get stuck...LOL...Oh yeah the car has a new tank..new fuel pump 155 lph..new everything really....I just spent in parts and labor $2300 on rebuilding this car So i hope it will run NOW...:rolleyes:
I had the same thing happen with my MSD dizzy a month ago, they use a ford PIP or whatever it's called and it displayed the same symptoms. Hopefully that's all yours was.......GL
thats nothing i bought a brand new ignition mod. when i got my hatch, car woudlnt do a damn thing so i said well maybe..... turns out the dude gave me a crap battery. but long story short the brand new ignition module broke on the first try..... got stuck in the on circut..... my dads going turn the car off stop trying to crank it.... as the cars trying to crank and wont start but the key was out of the ignition..... funniest moment of my life.
