I'm currently working on my 1973 Mustang and dropping in a 351C 4V that I just got done building. The car origianlly came with a 351C that I removed. Trying to set the motor back in,
it will not line up on the motor mount blocks
. I've check the blocks and mounts and they are the correct application. If anyone has any ideas or pictures it would greatly be appreciated so i can fire this thing back up!!
The motor looks to be in the right position but wont line up with the passanger side motor mount block on the K member. I'm thinking its just as simple as switching it around, but I'd like to double check first! Thanks for any help guys!!
Keep'em Crusin'
. I've check the blocks and mounts and they are the correct application. If anyone has any ideas or pictures it would greatly be appreciated so i can fire this thing back up!! The motor looks to be in the right position but wont line up with the passanger side motor mount block on the K member. I'm thinking its just as simple as switching it around, but I'd like to double check first! Thanks for any help guys!!
Keep'em Crusin'
