need help quick with!!!! (yes ive searched)
UnderdogGN
74
hey guys, i need help adjusting my 1.6 stud mount roller rockers...ive already searched all the threads but ive got so many different answers that im confused..i also dont want a link to a cam website because i just did the comp cams method of adjusting word for word and that did not work let me tell ya!
I know that it needs to be 1/2 to 3/4 turn on the adjusting nut after 0 lash on the push rod (slight resistance to spin) BUT,
I NEED TO KNOW WHEN TO DO THE ADJUSTING????? when which valve is opened or closed?????? this is where im lost at.....and you need to make your explanation dummy proof enough for a 17 year old lol thanks! also ive heard something about it has to be at top dead center???? school me please
thanks in advance!!!
The lifter must be at the bottom-most part of the lobe.
As in... turn the motor by hand untill the exhaust valve just starts to open, then you adjust the intake valve.
Make any sense yet?
When the exhaust starts to open, the intake is at the bottom-most part of the cam lobe, so then you set the preload 1/2 to 3/4 turn.
okay im getting it....so then its vice versa to adjust the exhaust valve? so it would be when the intake valve just starts to open then adjust the exhaust valve correct or no??
thanks
