Need Help really bad
00Perf RedStang
28
On my way home today, my what i belive to be coolant light came on, its the yellow one with a fan in the middle. So i stopped to put water in, and it was pretty much full, not even half of like a 32oz glass, so just to be on the safe side i checked my oil too, it was fine. Any idea on what this could be???
If by adding water it didn't fix the issue it's one of two things.
1) worst case: cracked intake.
2) bast case: bad float sensor.
First, thing I would do is unplg the sensor. It's located under the resevour (sp) tank to the right of your radiator. Unplug that sensor and see if that fixes it. I had the same problem and that's what it was. It can also be another sensor that is located on the intake. The part costs 20 bucks and is easy to replace. The float sensor alone can't be replaced (per ford so maybe it can be) you have to replace the entire tank.
Hope this helps.
