I recently had some 3.73 gears installed. What exactly do I have to do and where can I get what I need to correct the speedometer? Apparently I was going 130 mph down the access road but that just ain't right. Thanks for the input
Notice how the 3.55, 3.73 and 4.10 use the same speedo gear. That is because the speedo gear cannot be physically large enough to properly correct for 3.73 or 4.10. In your case, your speedo will read 5% faster than you are actually travelling (and your odo will be artificially inflated by the same 5% factor).Danman765432 said:I just went onto steeda's website and they have them, this is the info I got.
# Manual Transmissions with 8 Tooth Drive Gear
# 1990-1995 T-5 OEM
# 1996-1998 T-45 OEM Except Cobra
2.73 Gear Ratio / Yellow 18 Speedo Gear $9.95
3.08 Gear Ratio / Black 20 Speedo Gear $9.95
3.27 Gear Ratio / Red 21 Speedo Gear $9.95
3.55 Gear Ratio / White 23 Speedo Gear $15.95
3.73 Gear Ratio / White 23 Speedo Gear $15.95
4.10 Gear Ratio / White 23 Speedo Gear $15.95
http://www.steeda.com/
final5-0 said:Somthing that needs to be considered is, peeps who tell you about their experiences with this ratio and that number of teeth on the driven gear are great and all![]()
but
that don't mean you will obtain the exact same results.
Tire size makes a diff and the more diff between yours and theirs will cause the greater diff in your results![]()
Some t5's had different drive gears which I've seen from time to time that can make a diff as well.
besides all of that .............
Who says everybodys speedos have the same degree of accuracy![]()
I'd say if you have the same size drive gear as most t5's and you use a 23 tooth driven gear, that is the closest you are gonna get without ......
speed cal
or
drive gear change
I run 25" tall tires and my speedo reads about
+2 mph around town
+4 mph at highway speeds
most likely +6 around 100 mph
A speedo error that small concerns me not in the least bit![]()
to make me spend 100 bux on some magic box![]()
or
tear the trans apart to replace the drive gear which would then cause me to have to buy another driven gear![]()
play with this and you'll see what I'm trying to say here![]()
http://www.allfordmustangs.com/Detailed/608.shtml
btw ... Some have had issues with the 23 tooth driven gear wearing quickly as its not an exact, perfect fit for our cars. I've been runing one since 97 but my 95 is a weekend toy only.
Grady
Black95GTS said:You're right. But also consider its not only your speedo that is reading too fast, your odometer is reading too high.
Adam
