  • SN95 V6 Mustang Tech
Engine Need Help Tracking A Rough Idle On 2003 V6, Not Iac Valve.
  • Thread starter Thread starter F.D.K
  • Start date Start date Jan 3, 2018
  • Tags Tags
    engine idle issues
F
F.D.K
  • Jan 3, 2018
Need a second opinion on what the issue is. The car is a 2003 V6 mustang isn't anything fancy or have anything fancy on it. Spent last weekend trying to hunt down what I believed to be a vacuum leak. Turns out it wasnt a vaccum leak. Changed IACV after not being able to find any leaks. After that tested EGR valve and that seems to be working. The car itself when put in reverse shakes like high hell. It seems like it will rattle itself apart. Now when put in drive it accelerates decently with a little hesitation when the gears shift. Now once it slows down at a red light, the idle sits at 600rpms, now that's seems about right but it shakes in the brake and if you move it a tad forward the shake goes away. I was thinking something to do with the suspension but that wouldn't explain why I'm also only getting 188 miles per tank and that's highway. A little stumped, timing is right, good acceleration and no shaking when driving. Any ideas?
General karthief
Mod Dude
Aug 25, 2016
28,113
10,729
213
polk county florida
Jan 22, 2018
  • Jan 22, 2018
Have you done a tune up lately, plugs, wires or coils?
Also check the engine/trans mounts.
Checking for codes may help also.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 22, 2018
  • Jan 22, 2018
Check out this recent post. The take away from this is how the motor and transmission mounts can affect how it runs.
https://www.stangnet.com/mustang-forums/threads/3-8l-vibration-engine-swap.901933/
Reactions: General karthief
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
