My uncle has a 1991 ford mustang gt with a ford racing t5 transmisson. My question is after upgrading from a stock clutch to a ram heavy duty clutch and a lakewood steel bellhousing and changed out the clutch fork that was needed for the lakewood bellhousing, I also have a adjusted clutch cable that can be adjusted from the firewall or the clutch fork can not get it to shift properly it dose not glide into gear you half to push it in, also replaced the pivot ball that was recommoned for the lakewood bellhousing I was wandering if I dont have the pivot ball adjusted correctly how do you adjust the pivot ball without taking the tranmission out? Getting tired of taking it in and out any suggestions please let me know it would be greatly appercited. My last question is, dose the speedo gear in the tranny need to be changed to correct it for a 4:30 gear ratio what parts are needed?
Thanks for all replies
