need help with a sn 95 motor build questions on good setups
bfisk05
so i recently bought a sn 95 with a 5.0 ho in it.... just wondering what are my best options as far as an upper end .... i was thinking of going with the trick flow twisted wedge heads arp studs and trick flow lower and upper intakes....... just looking to get a little more power out of my stock gts. nothing to monsterous tho...... here's a link of the ones i wanted to buy... so my question is which cam should i use with these heads......
http://www.americanmuscle.com/trickflow-heads-7995.html
so which cam should i go with with these, can i use any cam with them.... or what... what are some of the setups you guys have on your cars.....
What is your goal with your car? did something mechanically go wrong with your heads? if you are just looking for power if so you will spend more on a new set of heads then you will on a good used blower kit for your car. As far as heads Trick flow has a quality Complete top end kit for your car that includes cams designed to run with the springs, and setup provided.
