need help with clutch problem asap
  • Thread starter Thread starter bsmotorsports
  • Start date Start date Apr 17, 2006
bsmotorsports
  • Apr 17, 2006
ok, when im pushing the clutch pedal in, it gets about half way down, and then makes a loud pop, seeming to be disengaging from pulling the cable, and then it continues to the floor. When letting up on the clutch, its making a ratcheting noise. The clutch has plenty of resistance when first pushing it in until it hits the pop, then it seems to lose a little, but still feels a bit firm. what could this be?
New cable?
dosent the 5.0 have an auto adjusting clutch thingy?
any help would be appreciated.
9
90lxfoxbody
264
  • Apr 17, 2006
i don't know what year your car is but yes alot of fox body mustangs come with a self adjustine clutch mechanism. just pull up on the clutch pedal and the plastic pawl on the quadrant will re-adjust. but, it sounds like the end of your clutch cable might be worn where it attaches to the clutch fork. i would check that out first. good luck.
bsmotorsports
  • Apr 17, 2006
the car is an 89lx 5.0.
-ben-
21
  • Apr 18, 2006
mine did exactly what you described, turns out it was hung up on something under the dash for a long time... 10 minutes later, the cable completely broke.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Apr 19, 2006
  • Apr 19, 2006
if you havent put an aftermarket quadrant in it than the stock quadrant is still there and its almost shot. check out upr or the stangnet parts shopper and get yourself a firewall adjuster and quadrant. ive got the fiore micro click adjuster and quadrant and couldnt be happier with how easily it adjusts and how well it works. if you really want some good info PM v8only or just wait and see if jeremy replies
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
D
2003 Mustang Steering pulls left bad after and accident , screeching while driving help please
  • dustbustet707
  • May 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
