  • 1994 - 1995 Specific Tech
need help with coil harness
  • Thread starter Thread starter jruppert
  • Start date Start date May 22, 2005
jruppert
294
Michigan
May 22, 2005
  • May 22, 2005
I had the harness off from the coil and the wires are a little loose from the connector. There are 2 wires that came out. One connection with 2 wires attached and one connection with one wire attached. I dont want to get these reversed so if anyone knows which way they go I would appreciate it. Thanks in advance.
O
One Wicked SVT
91
  • May 23, 2005
if they are reversed they simply wont work...
so if it isnt one way, its another.
went thru the same thing myself.
jruppert
294
Michigan
May 23, 2005
  • May 23, 2005
ok well i was just concerned about shorting something out. good to know, thanks
O
One Wicked SVT
91
  • May 23, 2005
i didnt have a problem with shorting anything out personally.
not saying its impossible or not.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 23, 2005
  • May 23, 2005
If you're careful you can use a small screwdriver and push the tab over that holds those metal connectors in the plastic connector -- releasing them. For my truck I had the same thing happen -- so I headed over to the junkyard, grabbed one off another car (they are the same for many years and models), and threw it back on. Good as new.
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Rally-Pac Wiring
  • Sparksteam
  • Oct 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 15, 2025
Sparksteam
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
