Need help with Distributor
Roxy89
38
Ok so I have been having a problem with my stang giving me problems starting and rough acceleration every once in awhile. Sometimes it starts fine and runs perfect, other times it doesn't. So I have a couple questions. First of all I pulled out the distributor and realized that the bottom part has a little bit of play to it. About 1/8" of movement up and down if I move it. Is this normal, or should it be completely still. I have a pic of it here showing where the movement happens.
I also was wondering how it is to reinstall the distributor back in. I have read a couple different threads on this, but I can't seem to figure out what I am feeling for in the spark plug #1 when I am cranking the engine. Also, where is the balancer that I have to check the mark of. Sorry if these are lame questions, but I haven't had experience with this yet on my 5.0 but have some mechanical knowledge and would rather do it myself then pay someone else.
Any info is greatly appreciated. Thanks.
To find top dead center you want to feel compression. You'll feel pressure coming out of the cylinder when you crank it. Another easy way is to use a straw, stick it in the cylinder until you can feel the top of the cylinder and crank the engine over by hand until you can feel that the cylinder is at it's highest point, just make sure that you are on the compression stroke and not exhaust or else you're timing will be out by 180*. Then check the that your timing marks are lined up on the balancer(balancer is located by the crank pulley, big rubber disc with a pointer beside it).
Is there any way to tell if it's on the compression stroke, or is it more of a trial and error thing?
Well if you are using the "finger on the spark plug hole" methos to determe TDC instead of using the straw method, you will feel compression on the compression stroke and nothing on the exhaust stroke.
Well when I use the finger on the hole method, it feels like it is sucking my finger in the hole, i thought it was supposed to feel like it was blowing it out. So would the feeling i am getting be the compression stroke?
Ok so I checked my distributor with a new one at the auto store and apparently the little up and down motion is normal. I also got it back installed and everything is running great. I don't have any pinging so my timing is fine for now, but I am going to try and advance it later. Thanks for your help.
