  • SN95 4.6L Mustang Tech
Need help with dyno results
  • Thread starter Thread starter 99GTFakeSnake
  • Start date Start date Apr 23, 2004
9
99GTFakeSnake
22
Cincinnati
Apr 23, 2004
  • Apr 23, 2004
This car is a 99gt with an 01 cobra swap. Car is running off of gt ecu with flashed program. flash was done through ford chip by mail order. Mods are:
bbk l/t, bbk h-pipe, with magnaflow cats, and magnaflow catback, u/d pullies, 255lb fuel pump. also running on stock gt maf.
The engine came from bishop. I've heard of people having problems with these engines. is it possible that this could a be a mechanical issue? Could my MAF be the cause of this problem? I have the stock my on the car from the 2v engine. Is there a difference between the cobra MAF and the GT MAF? Another question is when the motor was put in the knock sensor was not wired up. Could it be possible that the engine is looking for the knock sensor and pulling timing?
stangluver02
79
Going deaf from my exhaust
Apr 23, 2004
  • Apr 23, 2004
I couldnt read the hp on the dyno was it 255 or 285? Where are u in cincy I live about an hour southwest and I go to edgewater quite a bit. Pauls is a great place to get stuff done. And nice trap speed.
9
99GTFakeSnake
22
Cincinnati
Apr 24, 2004
  • Apr 24, 2004
It's 285, yeah i was down at Edgewater a couple weeks ago. Where do you live?
JonJon
4,801
back in Marylands
Apr 24, 2004
  • Apr 24, 2004
A stock 01 Cobra pulled 270/281 on the dyno day I went to...
http://dynoperformance.com/search_details.php?ID=675
Only 15rwhp from lt's, h pipe, pulleys?
  • Gulftown980x
  • Jul 29, 2026
squeak93
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
