Need Help with Ford Part Numbers, Fuel Rails, Stablizer Bar
RallyCobra
67
I need to know what applications these parts go to. ( What yr, Mach 1, Cobra, V6, Explorer, etc.)
4.6 2V Fuel Rails
Drivers Side 7K16X1
Pass side 7K08Y2
Front stabilizer bar on a mustang
XR3Z-5482-DA
Rear stabilizer for mustang
F7ZZ-5A772-AA
Thanks so much!
fuel rail part numbers are no good. they need to follow the same format as the anti-roll bar part numbers. I can check on my computer at work tomorrow to get you applications.
just from looking at the numbers for the anti-roll bar part numbers the first one was first used in 2000 and the second was first used in 1997 model years.
Thanks BD!
I can give more info on the rails. They are stamped with the word Ford, and the codes I listed are on the front of the rails near the front of the car. They appear to be a return style rail, and work with the coil on plug of my 01GT. There is a small canister on the front of the passenger rail with a vacuum port, which I assume is a fuel pressure regulator. I can post a pic in a couple of days if that helps. Are they just regular 96-98 4.6L fuel rails?
