need help with misssing problem.
  • Thread starter Thread starter BK_CAULEY
  • Start date Start date Apr 17, 2007
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Apr 17, 2007
  • Apr 17, 2007
i have already done a search and tried everything i can do to make it go away. when i get in the higher rpms (above 3500) i am experiencing a very light cut out. it just is noticable but it is there. its not a real hard cut out or miss is soft but i cant narrow it down. i checked plugs and they look good. wires rotor and cap are all new. i replaced my fuel filter and even added a fuel treatment to make sure i had no water n the tank. im at a loss and dont know what to check for next.
4G-KDMP
935
CA
Apr 17, 2007
  • Apr 17, 2007
jrichker should be here shortly to help you.
there isn't much he doesn't know when it comes to problems like this.
KcMstang
1,563
Hamilton, Georgia
Apr 17, 2007
  • Apr 17, 2007
Pull the codes! Are your plugs gapped right?
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Apr 17, 2007
  • Apr 17, 2007
there is no codes and there gapped at .035 thats what they have always been.
BigHairyMonkey
411
Houston (Bellaire) TX
Apr 17, 2007
  • Apr 17, 2007
i was under the impression plug gap should be set at .054
BigHairyMonkey
411
Apr 17, 2007
  • Apr 17, 2007
and also have you tried pulling the codes or are you under the impression there are no codes because of no CEL light?
ninety15.0
1,336
  • Apr 17, 2007
Plug gap should be set at .054"
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Apr 17, 2007
  • Apr 17, 2007
no i have pulled the codes many times, and tried the other day. and i have always had my plugs at 35-40ish and have never had anyproblems. this just all of a sudden started.
Fett
766
  • Apr 17, 2007
Is it under accel or just cruising?
One easy thing to check is unplugging the vac line to the EGR. Just pop the vac line off the EGR and stick it on the bolt that holds the AC accumulator onto the firewall. It will block off that line so you don't get a vac leak. With the vac line off the EGR go take it for a spin and see if the problem went away.
It might not be your problem, but I was experiencing the same thing you described, and went through the usual routine, plugs, wires, cap, ect. I unhooked the vac line to the EGR (disabling it) and the problem went away. The EGR gradually opens and closes, mainly at cruising speeds. They can develop basically a dead spot, and will open too far, then close all the way rapidly, causing the exact problem you are describing.
Like I said, this might not be your problem...but it will literally take 5 minutes to check so you can at least rule that out as a possible problem.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 17, 2007
#10
  • Apr 17, 2007
  • #10
Does the problem occur mostly on a warm or hot engine? Or does it happen all the time? No codes?
hogt2
385
Montgomery,IL.(West of Chicago)
Apr 17, 2007
#11
  • Apr 17, 2007
  • #11
i had a similar problem under hard acceleration above 3500 rpm. Did all the usual changing of parts with no change in miss. Then I bought a cheap coil to replace the one I had. That fixed the problem. My coil was junk. I then bought a MSD coil to replace the cheap one I used for diagnosis. This could be your problem. Good luck.
angeljenylynn
20
Louisiana
Apr 17, 2007
#12
  • Apr 17, 2007
  • #12
make sure your timing is ok, mine was off just slightly and it missed JUST a bit, like you're saying.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Apr 18, 2007
#13
  • Apr 18, 2007
  • #13
I havent thought about that. i will try it today.
It happens all the time. and i had no codes. just 11.
It might be the coil i will also try that today.
Once again i havent thought about my timing, will check that also.
thanks for the input guys.
N
noslow1986
274
oswego Il
Apr 18, 2007
#14
  • Apr 18, 2007
  • #14
same problem bad coil
angeljenylynn
20
Louisiana
Apr 18, 2007
#15
  • Apr 18, 2007
  • #15
hope you get it fixed. let us know what it was!
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
  • Locked
Engine Help timing possibly
  • K1tha1
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
