What would be the next step in mods???? I'm thinking short throw, underdrive pulleys, C&L plenum, 75mm TB, and a Steeda CAI. With all that and the mods I already have I would like to run high 13's
I've got pulleys and T/A. They seemed to make a substantial increase in low end power. I'm happy with my Steeda Triax shifter. It would sure be nice if it was cheaper though. I honestly wouldn't get a cold air intake. I would just get a cone filter. I had a cold air and switched to just a cone filter, and it feels faster
Do the pulleys and T/A at the same time. Good SOTP, very noticeable difference. The Steeda ones are good. All together that would run you about $300 (more if you don't install them yourself).
I can feel a real SOTP difference after installing the C&L Mass Air kit, C&L True-Flow pipe, AccuFab T/B and C&L Plenum. No dyno yet, but it is very noticeable and the throttle response is so much better! This stuff cost about $750 and you can install it yourself.
Another thing to think about is the PI intake swap. You can find one for about $100 and I hear that nets about 20hp, but the install can be tricky because the ports don't match up quite right.
