Need help with Nitrous install..
  • Thread starter Thread starter 91slow5.0
  • Start date Start date Nov 9, 2007
9
91slow5.0
9
Afganistan for another 10 months.
Nov 9, 2007
  • Nov 9, 2007
Ok so im pretty new to the Mustang thing.. Id like to start off, i have a 91 Lx 5.0 only mods done to the engine are e303 cam and ported e7's. I just recently purchased zex race EFI wet kit. I also purchased a 190 lph bbk fuel pump. My question is what all do i need to make this run right and how much of a shot should i run? I was planning on 24 ilb inject, Maf sensor for them, a bigger throttle body but i dont know how big and a cobra intake. Also a fuel pressure reg. Please tell me if im missing anything or have this all wrong.
Thanks,
Mike
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Nov 9, 2007
  • Nov 9, 2007
sunds like you are on the right track to me. did you buy the zex kit new or used? and IMO they are one of the more safer kits to use out there.
rsw007
469
Lexington,SC
Nov 9, 2007
  • Nov 9, 2007
if its a stick car you may want a window switch and some really good tires.
if it hooks and bogs down off the line "BOOM" window switch will cut off nitrous if car boggs. ive seen the upper intake blown off a stang before.
RYC CUKR
1,437
Orlando
Nov 9, 2007
  • Nov 9, 2007
A window switch should be mandatory on all nitrous installs. I have one on my AOD car.
Keep in mind that with a wet kit you do not need to up the size of the injectors specifically for the nitrous. So if you you don't need the 24s with your current mods then you won't need them is a wet kit. Dry kits use the injectors to add the extra fuel while wet kits use the fuel jet to add the correct amount of fuel.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
