Need Help With Procharger P-1sc
WrecklessWonder
So I've reach a stopping point and hoping someone else on this forum has been in the same situation or knows someone who has. I recently purchased a Procharger kit and in the process of installing currently. My issue is my car has a manual flaming river rack, no smog, with A/C. I've at the point that I've determined the Procharger belt tensioner is position between the crank pulley and the A/C pulley. Based on this position in order for the engine serpentine belt to function properly I need the power steering pulley so the belt flows around the charger tensioner correctly. After many hours of searching it doesn't appear that anyone makes an idler pulley setup to replace the factory power steering setup. Does anyone know of one or a different thought around how to work around this? Thanks in advance. BTW - Fox body 93 Couple 5.0
