I got myself a set of slotted rotors and decided to change out the disk pads. All went well up front but on the rear I cannot get the brake piston to compress enough to re-install the caliper assembly. I used a large C clamp and ended up twisting the steel handle into a crooked mess. Put the assembly back on the spindle and tried a pry bar. Even added my 25" breaker bar for additional leverage. It won't move. Any ideas are greatly appreciated as my car is now forever stuck on the floor jack. (I also have the master cylinder lid off so that the fluid can back up into the resevoir. I even tried opening the bleader valve at the caliper to no avail thinking that the pressure would release easier.
BTW this is a 97 GT
BTW this is a 97 GT
