Need help with Screwy H pipe
GodZilla37
I have a Stock h-pipe that I am going ot put on my 88GT when I picked it up last night it sounds like there is a piece of solder or metal screw inside from the rear cat to a front cat. I shook the crap out of it to try and get it out but no luck. I tried to make it go down the connector pipe in the middle but no luck. My question is it stopped rattling but is it safeto put it on with it in or how can i get it out or should I take it out before putting it on?
thanks
We dont even know what is broken or where. I've had cat substrates break in the middle of the cat housing. You couldnt remove it if you wanted to. And the noise resonates around so it's hard to pinpoint.
If you wanted to explore, I suppose you could take a unibit and drill a hole between the two cats and see if there's something rattling around in the middle of the two cats.
Good luck.
I got a long pointed bar about the diameter of a lug wrench,stuck in the H-Pipe (with it removed of course),and beat that stuff out using hammer to hit the bar with.It took about an hour,but after that stuff was out,empty cats,and no rattles.Now I have an X-Pipe,so no worries with that.
Monte, more info on the recall please. I'm one of the few who still has the stocker around.
Thanks bud.
sounds
it sounds like there might be a screw in there. it is in the pipe in between the front and rear cat. when I shake it it moves freely from front to back. when i shake it side to side it rolls like a screw would laying down. I have tried ot shake it out throught the small connector tube but its kind of heavy to hold and do that and gently coax it towards the small hole. Id prefer to get it out before i put it in.
Thanks bud.
I gave the TSB number and issue date above. I got a postcard in the mail from Ford because I am the original owner. I had mine replaced, took them off within a year for Mac hi-flow cats and then sold the almost new factory cats.
If I remember correctly, the defect was internal baffles breaking loose and causing a rattling sound. If the part number/manuf date of the cats matches the recall, you get new ones for free. Because it's emissions related, it's good for 10+ years or maybe more. You gotta contact the dealer on this one, just like the ignition switch recall.
Thank you sir. In typical fashion, I got excited after seeing your opening line and missed the rest of your post. :bang: I'll check it out.
:OT: I haven't had a chance to try the Corrosion Block yet. My bud did get a product called TC-11 and should have feedback at some point if you're ever interested [for reference or comparison's sake]...................
