Just putting white 23 tooth speedo gear in the 93 AOD.
It doesn't seem to fit down far enough to allow the safety clip in.
Is this normal, or should I drill out a small bit (2mm) of the inside of the gear to make it fit?
Also, I broke the bolt that hold the assembly to the transmission housing. I don't have time to put a drill in there right now, any quick fixes?
