  • 1994 - 1995 Specific Tech
need help with speedo gears
  • Thread starter Thread starter inphiniti
  • Start date Start date Jun 23, 2008
I
inphiniti
412
Providence, RI
Jun 23, 2008
  • Jun 23, 2008
im going to be runnin 4.10s, but i dont know what size gear tooth i need... some say 23, but some say 23 is a GM product...
what do i successfully need to run 4.10s in an auto?
C
cbarr300
746
goose creek, SC
Jun 23, 2008
  • Jun 23, 2008
get a speedcal and that'll solve all your problems with the speedo
Venom351R
4,548
41
98
MAINE
Jun 23, 2008
  • Jun 23, 2008
http://mustangsunlimited.com/itemdy00.asp?T1=DFM17271J+01
Black95GTS
1,644
Marlborough, MA
Jun 23, 2008
  • Jun 23, 2008
The 23 tooth gear is white, and its a Chrysler gear. Ford gears only go up to compensation for 3.27s (21 tooth). The 23 tooth Chrysler gear will be dead on for a 3.55 gear set. Its close for the 3.73 and still off a bit for the 4.10. It has a reputation for wearing faster due to the chrysler gear not meshing exactly with the Ford gear.
The SpeedCal (or something like it) mentioned above is the only way to get the speedometer and odometer correct and run a 4.10 screw.
Adam
Stanger007
2,015
Baton Rouge, LA
Jun 23, 2008
  • Jun 23, 2008
If anyone has a 23tooth and a Ford gear, it would be worthwhile to mic them both and see if the OD of the 23 tooth is larger.
I had seen someone that mounted their 23tooth in a drill then hit it on a piece of sandpaper to bring down the OD and supposedly that made it live longer?
I've got the SpeedCal, actually about to be on my 3rd... first one lasted a good while then started behaving erratically, second one was DOA (read 4x lower than it should despite DIP settings) and third one is in the mail. When they work, they work great. From talking to Dallas Mustang, I am the only person in history to have problems with them, go figure.
Wes
I
inphiniti
412
Providence, RI
Jun 23, 2008
  • Jun 23, 2008
Wes
i hear alot of people have problems with their speedcals... and sometimes i hear the 23 tooth will do the justtice... i might just go that way, who feels like spendin $100 on a speedcal neways... ill just tell my buddy to ride along side of me and tell me how fast im goin
Stanger007
2,015
Baton Rouge, LA
Jun 23, 2008
  • Jun 23, 2008
I'm still split on how having the speedo off affects automatics - particularly the part throttle shifting/locking which is based off MPH/TP - on one hand it seems like it is off initially but that the PCM learns. I have not found out for sure nor found anyone that could properly explain it... wierd eh?
Wes
Venom351R
4,548
41
98
MAINE
Jun 23, 2008
  • Jun 23, 2008
I also forgot to mention to you that I have a Manual, I know you have an Auto so Im not sure how much difference that will make as far as the speedo gear longevity
earleys94gt
1,223
Ashley, Ohio
Jun 23, 2008
  • Jun 23, 2008
Steeda has a good list too...http://www.steeda.com/products/speedometer_recalibration_gears.php
blksn955.o
3,263
st.louis mo 314
Jun 23, 2008
#10
  • Jun 23, 2008
  • #10
Is it possible to mess with the voltage of the VSS to make up for the wrong speedo gear? I have no idea...just asking or is it because there is no real conection with the speedo (guage) and eec?
Could one hook up a resistor of some kind to slow the pulse down?
I am just thinking of a way to maybe make one?
Stanger007
2,015
Baton Rouge, LA
Jun 23, 2008
#11
  • Jun 23, 2008
  • #11
I got my (third) SpeedCal put in tonite. Ended up putting the replacement in my car, same deal, so put it in another SN95 and it was still not reading correctly. Took it back off and then found out that the DIP switch settings that came with both units are wrong.
I found a better list of the settings here: http://lib.store.yahoo.net/lib/mustangtuning/speedcal.pdf
On the plus side, I can R&R these things in about 10 minutes on an auto now.
Works like a charm...
Wes
Black95GTS
1,644
Marlborough, MA
Jun 24, 2008
#12
  • Jun 24, 2008
  • #12
I don't know if you plan on selling that car, but the readings on your odometer are going to be that much of a percent higher. Just something to think about. If I was buying a car and the owner was like "Well there really are 10K less miles, I just didn't want to install the right counter measures when I switched to 4.10s." I'd be like OOOOOOOK next car, have a good one.
In terms of modding the circuit manually, I don't see why this couldn't be done, but it would be an awful lot of work.
Adam
I
inphiniti
412
Providence, RI
Jun 24, 2008
#13
  • Jun 24, 2008
  • #13
yeah the car is paid for, it was a gift so it was not out of pocket... the car isnt going anywhere...
94-302-vert
1,947
NE CT
Jun 24, 2008
#14
  • Jun 24, 2008
  • #14
I vote speed cal too...
WhiteCobra95
641
180
74
Jun 24, 2008
#15
  • Jun 24, 2008
  • #15
I don't think you can modify the sensor circuit directly since the vehicle speed sensor outputs a PWM signal. The Speedcal is essentially reading these pulses, and then outputting another PWM signal at a different frequency to compensate for the gear change. In short, it's not an analog voltage signal that can be adjusted. (I'm not sure if Ford uses an inductive or hall effect speed sensor? I'll have to check the shop manual and see if it has a supply voltage)
The least expensive but most labor intensive solution is to open up your transmission and change the drive gear along with the driven gear to the older style (late 80's used a different number of drive teeth). Check out the FordRacing Parts catalog. They have half of a page dedicated to speedometer corrections. It gives part numbers for all of their gears, drive and driven. These can all be purchased at the dealer. This opens up the door for way more rear end combinations and if it's done correctly taking tire size into account, could give you the best result. It's not too bad on a MT car - you have to pull the shifter and the tailshaft off of the trans. This information is also available on the fordracingparts web page, but I can't get to it through my work computer since it's a flash site. Maybe someone else can post a link.
- Mike
I
inphiniti
412
Providence, RI
Jun 24, 2008
#16
  • Jun 24, 2008
  • #16
idk, i hear 50/50 on the speedcal... i hear it works... i hear others say it doesnt... i dont know what to do, id like to stay away from it if possible... just not sure what else to do..
what does the speedcal EXACTLY do... and what does the drive gear do?
WhiteCobra95
641
180
74
Jun 25, 2008
#17
  • Jun 25, 2008
  • #17
Here's the link. Check out the bottom of the page.
http://www.fordracingparts.com/download/charts/142.pdf
94-302-vert
1,947
NE CT
Jun 25, 2008
#18
  • Jun 25, 2008
  • #18
The speed cal takes the signal input from the exisitng trans output and it sends out a new signal that corrects for the change in gears. This can be almsot infinitely altered if you change gears, tire sizes, etc.
The gear change is cheaper, does not last as long, and is not going to e accurate....
WhiteCobra95
641
180
74
Jun 26, 2008
#19
  • Jun 26, 2008
  • #19
I read through the FR details last night. It looks like it's not possible to change the drive gear on the AT's, and it comes in too short for 4.10 gears. It looks like the speedcal is the only option for am automatic.
I have a question about the speedcal installation; Do you have to cut any wires to install it, or doesnt it just plug in between the sensor and the harness? That would really be a bummer if you have to dice yoru harness.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
