Need help with stripping my interior
  • Thread starter Thread starter WhiteThunder
  • Start date Start date Oct 12, 2008
WhiteThunder
52
  • Oct 12, 2008
Well, I ripped out the carpet and have everything almost ready to use Por15 on the floorpan but I can't get the e-brake out. The tension on the cable is to great so when I unbolt it it jerks back against the opening in the floorpan. Also the box (Sorry, don't know what it does to specify) behind the e-brakeis riveted to the floorpan. How am I supposed to get that out? Any help would be appreciated, I'm stuck on this and would like some input before I go messing stuff up.
D
Deleted member 87397
Oct 12, 2008
  • Oct 12, 2008
You are probably going to have to unhook the ebrake cable from underneath before you can take it out. Either at the ebrake or at the brakes. As far as removing something with rivets, the only way to remove them is to drill them. If you drill them whatever is mounted there will not go back in unless you redo the rivets with a riveting tool or just find a way to bolt it back in using the rivet holes. Good luck.
Nova
128
  • Oct 12, 2008
you have to crawl under the car and undo the bolt down there. should be above the exhaust and draveshaft in the tranny tunnel
WhiteThunder
52
  • Oct 12, 2008
Thanks guys. Sounds like this is going to be fun. Hopefully it wont be to bad once I comandere a jack. I unfortunatley don't own a garage and I'm having to work on a gravel driveway.
Nova, is there a bolt that just holds the e-brake together? Or is it a tension adjustment?
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
D
Need to find manual release lever for convertible top
  • dickforen601
  • Jun 29, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 2, 2025
dickforen601
D
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
D
Need help for my PCM Mach1
  • Danaololo
  • Jul 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 30, 2025
Danaololo
D
1987 Mustang GT Mass Air Conversion Help
  • mustangmike6996
  • Jan 1, 2025
2K
Fox 5.0 Mustang Tech Feb 4, 2025
mustangmike6996
