Need help with Tach install
Kdubslugga
1,515
Akron, OH
I just bought a Phantom 5" Tach and I got the wiring done except the one to the coil. Im assuming i have to splice into the blaster coil but im not sure which wire to cut, I think its the tan one with a yellow stripe, I just wanna make sure this is right!!!
Ack, dont cut any wires. You splice *into* the negative side of the coil.
Now if you have a MSD box too, there's a port for the tach hook-up.
Good luck.
Ignition coil wire legend:
Red/Lt green wire: Positive side switched power from the ignition switch. Use this one to supply power to the tach.
Dark Green/yellow: negative side signal to the TFI module. Use this wire to sent the signal to the indicator circuitry inside the tach. This wire pulses every time a cylinder fires.
