  • SN95 V6 Mustang Tech
Need Help With This PLZ
  • Thread starter Thread starter griffon996
  • Start date Start date Oct 15, 2007
G
griffon996
Roswell N.M.
Oct 15, 2007
  • Oct 15, 2007
I am changing or tring to change clutch on 96 mustand with v6 and have tranny removed and ting to get the bellhousing off but there is 2 stripped bolts holding it in have tried using an extractor set but can not get a good enough bite on bolts need help cant do it plz any suggestion would be greatly appreiciated
Skymarshal
572
Dallas
Oct 16, 2007
  • Oct 16, 2007
Drill them out, drill a new oversize hole, tap it, and use a new bolt is the only thing I can say....
R
Robs96
131
  • Oct 18, 2007
Which bolts are stripped?
fastford91
254
Niagara ,Ontario, Canada
Oct 18, 2007
  • Oct 18, 2007
are the threads striped or is it the head of the bolts that are striped? if it the heads on the bolts just use a good set of vice grips !your going to have to replace them anyway so use whatever you can to get a good strong grip on them and get them out!
98V6 K.I.T.T.
2,049
Everett, Washington
Oct 20, 2007
  • Oct 20, 2007
Yeah, I think specification on whether it's the threads or the top of the bolt that strips would help. I would however try this first, take some WD-40 or other penetrating lube like PB blaster etc....spray it heavily around the bolt let it sit for 10-15 minutes and try and take them off. If it's the top of the bolt, using a vice grip or something similiar would help, if not try a breaker bar if you haven't already. If it's the threads that are strip, then best is to drill it out or if everything else isn't working. Don't drill unless you eliminated other possibilities.
G
griffon996
Roswell N.M.
Oct 23, 2007
  • Oct 23, 2007
I would like to thank everyone for input
i would like to thank all of you that replyed to my message i finally got them off it was the head of the bolt sorry didnt say that before but had to cut the heads of with saws all and know got it done and wife back on road in her mustang thank you everybody next hobby putting on a dual exhaust for her !!!!!!
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
