Need help with wiring
  • Thread starter Thread starter krallman
  • Start date Start date Mar 27, 2007
K
krallman
96
Hurricane, WV
Mar 27, 2007
  • Mar 27, 2007
Okay my car is ready to go.... Except for wiring. The car is going to be racing on a circle track. Its an 85. It was a cfi with an overdrive. But now its a 289 4 bbl with a c-4. Does anyone have a simple diagram to wire this car up. All i need is to have is what will make it run, no lights, accesorries other than water temp, oil pressure and a tach. I have a new solenoid, new battery, new voltage regulator. It will be push button start. so i dont have a key. So if anyone could help it would take some strain off. The old wiring harness is completely out of the car but i still have it.
Aryan15
236
CA
Mar 27, 2007
  • Mar 27, 2007
It depends on what kind of ignition sytem and charging system you want to go with. It sounds like your simplifying things so I would go with a one wire alt. and HEI distributor. Typically its 12v to the coil with the negative going to the distributor. The alt. wire goes to the starter relay with fusible link. Youll need an ignition switch to power the coil(12v fused to the switch and back to the coil).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 28, 2007
  • Mar 28, 2007
See the following sites for help.
http://www.jason.fletcher.net/tech/duraspark/duraspark.htm
http://www.carbdford.com/tech/HEI/hei.htm
http://www.jason.fletcher.net/default.htm
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
