  • SN95 4.6L Mustang Tech
Need Help??
  • Thread starter Thread starter blue46gt
  • Start date Start date Nov 25, 2004
blue46gt
53
WA
Nov 25, 2004
  • Nov 25, 2004
I still have a problem with my idel on cold start ups. When I first start my car the idel jumps up and then idels really rough and dies. Then most of the time when I start it the second time it's fine. I cleaned the IAC but it still does it. Someone told me to clean the MAF wires but I'm affraid of breaking them. I thought of trying to adjust the TPS but I thought it was not adjustable on my 2000 GT. Any ideas?? Thanks All!!
8yourZ06
128
  • Nov 25, 2004
My car did something similar other than starting a second time and being ok. It turned out to be the fuel pump control module. I would plug in a code scanner and see what codes if any the computer throws up.
blue46gt
53
WA
Nov 26, 2004
  • Nov 26, 2004
Check the codes on my car and the only thing I get is a fault oil pressure switch. My car did it again when I fired it up this morning. This is pissing me off. I think I'm gonna go and buy a new TPS. Hope that works.
rustang04
Banned
May 4, 2004
239
  • Nov 26, 2004
spray a little electrical/ or brake cleaner on the maf wires abd blow them off w/ an air blow gun w/ only a little pressure. don't run out and buy tps. also put your stock maf back on and see if it still does it
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
