  • SN95 4.6L Mustang Tech
need help
  • Thread starter Thread starter Taha
  • Start date Start date Aug 22, 2010
T
Taha
  • Aug 22, 2010
dear all,
can anyone help me.
i've mach 1 04.
BBK ceramic long tube, polleys, k&n air intake, bbk x-pipe with borla mufflurs, short shifter and 4.10 gears
my Q is:
when i checked with my SCT device it always shows ignition coils error but my car is running fine till 4th gear 5000rpm , after 5000 rpm its goes faster till 7000 rpm ( like there is NOS )
cleaned injectors, new fuel filters and new spark plugs.
need advice for choosing the ignition coils. i've found OEM ( stander ) and weapon X,
appreciate your cooperation
trinity_gt
3,125
81
99
Canada
Aug 22, 2010
  • Aug 22, 2010
Before throwing parts at anything, what are the specific codes the scan tool/SCT is returning?
Keep in mind that a stock Mach 1 makes its most power at 5800RPM. Your mods may have moved that power peak slightly higher still so you'll see the best peformance above 5K anyway...
T
Taha
  • Aug 22, 2010
yes bro, but its take longer time to reach to 5k than before and u can feel like a nos after 5.5k till 7k. i think there is somthing wrong. ill check the code later and ill replay u
anyways thank you
trinity_gt
3,125
81
99
Canada
Aug 22, 2010
  • Aug 22, 2010
You said "...my car is running fine till 4th gear..." and then implied that it gets an N2O-like shot above that. I don't draw from this description that the car has a problem below 5000, mostly because you said it was "fine".
So is the car actually somewhat sluggish-feeling below 5K?
T
Taha
  • Aug 22, 2010
and the error is in ignition coil B, C, D, E,G and low response from o2
i think ill change the ignition but which one do you prefer OEM ( the orginal ) or weapon X ?!!
T
Taha
  • Aug 24, 2010
i turn off the EGR from my SCT tuner and now it shows only one ignition error
the error msg as the below :
P0353
ignition coil C
(cop-c)
primary/secondary ckt
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Desperate help needed
  • BlueChappy570
  • Oct 25, 2022
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Nov 4, 2022
manicmechanic007
R
Bad Vibration at 2000-3000RPM
  • Rona
  • Apr 16, 2022
6K
Fox 5.0 Mustang Tech Jul 20, 2023
85GTStangGuy
