  • SN95 4.6L Mustang Tech
Need information help
  • Thread starter Thread starter starkiejr
  • Start date Start date Jun 11, 2005
starkiejr
New Castle DE
Jun 11, 2005
  • Jun 11, 2005
I need some help here guys...and girls...lol
I have a 2000 GT Convert and need to find out what number spline axle I have. Does anyone know if I have a 28 spline or a 31 spline? I want to get 3.73 gears and need to know which number spline I have. Any help would be great. Thanks.
awwyea
170
Central MA
Jun 11, 2005
  • Jun 11, 2005
Factory should be 28. While it is recommended that you upgrade to 31's when you change gear, it's not mandatory unless you are packing in some serious engine mods with it or plan on racing it on a regular basis at the track. For just day to day driving and a few stop light races, you don't need the 31 spline axel, the 28 will suffice as long as you practice self control and not beat the snot out of it off the line every time.
starkiejr
New Castle DE
Jun 11, 2005
  • Jun 11, 2005
Thanks awwyea. Now is this something that is already on the car or is this something I have to buy along with the 3.73 gears? Thanks
Brian
awwyea
170
Central MA
Jun 11, 2005
  • Jun 11, 2005
The 28 spline axles are already in your car. You would only have to replace them if they are worn or a piece is broken from one of the spline. Also, since you have to remove the axles to make the gear change I would recommend that you replace your axle bearings. Everything is already out and its a small expense now which will save you a big time headache down the road. Nothing worse than to put it all together and have the axle bearing go a short while later.
When you replace the gears you will need a shim kit along with the ring & pinion, pinion bearing & race, rear differential fluid, a tube of form a gasket, differential gasket and friction modifier. Are you installing them yourself or having them done somewhere? The hardest part is getting the new shims in place in the correct order. If they aren't in there right, it won't line up.
Hope this helps... Carol
starkiejr
New Castle DE
Jun 13, 2005
  • Jun 13, 2005
Thanks Carol. I called my brother and he said he has the 3.73 gears and I can have them. He said he would put them in and he said he has all the stuff that I will need. Thanks again.
Oh, my brother is starkie on here and his mustang runs way better than mine..lol...but I am sure I will never catch him..lol
Give Me TP
936
Republic of Texas
Jun 13, 2005
  • Jun 13, 2005
I use stock 28 spline axles with 4.10s in my car with no problems yet after 30,000+ miles. Mine is a daily driver though and is not subject to regular track launches.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 13, 2005
  • Jun 13, 2005
You have 28. You do not need to change them.
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
