Need input - Codes and Check Engine Light
  • Thread starter Thread starter new46stang
  • Start date Start date Jan 18, 2007
N
new46stang
146
AZ
Jan 18, 2007
  • Jan 18, 2007
Hello All,
Ok so recently I have had an issue crop up.
Car:
91LX AOD. 151k mi. Everything is stock except a 190lph fuel pump (which was installed after I was having the issue below).
Codes:
First round got a 13 KOEO and 13 KOER. ( I think this one had to do with RPM can not reach lower limit. My tac is stck at 4k. Does this have something to do with it?)
The second round I think it was the code where needs to learn the idle. (somehow I may have reset the computer.)
Issue:
My "Check Engine" light flashes occationally. Seems to pop on more so around
70ish mph. Really no rhyme or reason. Based on the history above, does anyone have any ideas why this is happening?
TIA
Matt
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 18, 2007
  • Jan 18, 2007
Code 13 - Key on Engine off - ISC did not respond properly (extends to touch throttle then retracts for KOEO) – ISC
Key on Engine running - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
If your idle is above 725 RPM, the computer will set this code. Normal idle speed is 650-725 RPM. Higher than that means that someone has mechanically set the idle speed by use of the idle speed screw, and has effectively disabled to computer’s ability to control idle speed.
N
new46stang
146
AZ
Jan 18, 2007
  • Jan 18, 2007
Hey Jricker,
Thanks for the reply. I actually have no idea what the car is idling at cause of my stupid tac is stuck at 4k. I'll look into that idle some how. What do you think about the check engine light flickering? Could it be a short?
Thanks again,
Matt
N
new46stang
146
AZ
Jan 19, 2007
  • Jan 19, 2007
TTT
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
